Ersatzteile für Gorenje Klimagerät (258491)
Gorenje
Klimagerät
35000185 SCREW C ZN YSMB M4*8 ROHS
1061883
35000185 SCREW C ZN YSMB M4*8 ROHS Befestigungsteile
30001830 CONN HEADER 2P 2.5MM TOP BLUE SD
1062649
30001830 CONN HEADER 2P 2.5MM TOP BLUE SD Verbinder/ Kabel/ Stecker/ Adapter
30001838 CONN HEADER 3P 2.5MM TOP YELLOW SD ROHS
1062698
30001838 CONN HEADER 3P 2.5MM TOP YELLOW SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30001850 CONN HEADER 6P 2.5MM TOP WHT SD
1062730
30001850 CONN HEADER 6P 2.5MM TOP WHT SD Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30001851 CONN HEADER 7P 2.5MM TOP WHT
1062736
30001851 CONN HEADER 7P 2.5MM TOP WHT Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30006660 CONN HEADER 4P 2.5MM TOP WHT SD
1062898
30006660 CONN HEADER 4P 2.5MM TOP WHT SD Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30006709 CONN HEADER 5P 2.5MM TOP WHT SD
1062905
30006709 CONN HEADER 5P 2.5MM TOP WHT SD Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30014191 CONN HEADER 12P 2.54MM TOP WHT
1063054
30014191 CONN HEADER 12P 2.54MM TOP WHT Verbinder/ Kabel/ Stecker/ Adapter,Stecker
35000183 SCREW C ZN YSMB M3*12 ROHS
1063066
35000183 SCREW C ZN YSMB M3*12 ROHS Befestigungsteile
30022542 CABL 2P /250 SPK SIS UL1007 AWG24 ROHS
1063094
30022542 CABL 2P /250 SPK SIS UL1007 AWG24 ROHS Verbinder/ Kabel/ Stecker/ Adapter
35006091 SCREW VGA SOC.UNC4-40/UNC4-40 89890-0085
1063096
35006091 SCREW VGA SOC.UNC4-40/UNC4-40 89890-0085 Befestigungsteile
40014842 BOTTOM COVER RC 1542 EKO2GRAY(I) ROHS
1063231
40014842 BOTTOM COVER RC 1542 EKO2GRAY(I) ROHS Gehäuseteile
30020181 CONN ASSY 1.5M (PC-TFT TV AUDIO CABLE)
1063318
30020181 CONN ASSY 1.5M (PC-TFT TV AUDIO CABLE) Verbinder/ Kabel/ Stecker/ Adapter
30025362 CNAS 1P/2000 W/DSTRJACK
1063320
30025362 CNAS 1P/2000 W/DSTRJACK Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30018374 CONN HOUSING 24P 1.91MM SIDE DVI ROHS
1063325
30018374 CONN HOUSING 24P 1.91MM SIDE DVI ROHS Gehäuseteile,Gehäuse
30037619 CONN HEADER 10P 2.5MM TOP YLW SD ROHS
1932201
30037619 CONN HEADER 10P 2.5MM TOP YLW SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
35005418 SCREWPCZNYSB3.5X10(KN1031T35X10)ROHS
1932230
35005418 SCREWPCZNYSB3.5X10(KN1031T35X10)ROHS Befestigungsteile
20181842 BRACKET POWER LCD 3007/08 EKO2.GRAY (I)
1932259
20181842 BRACKET POWER LCD 3007/08 EKO2.GRAY (I) Befestigungsteile,Halterungen/ Halter
30012385 CONN HEADER 4P 2.5MM TOP RED ROHS
1932286
30012385 CONN HEADER 4P 2.5MM TOP RED ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30029522 CONN HEADER 12P 2.5MM TOP BLK ROHS
1932316
30029522 CONN HEADER 12P 2.5MM TOP BLK ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30018843 CONN HEADER SAFE 2P 7.92MM WHITE ROHS
1932432
30018843 CONN HEADER SAFE 2P 7.92MM WHITE ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
CNAS 5P/700 FLT W/C UL2468AWG24 ROHS
1932526
CNAS 5P/700 FLT W/C UL2468AWG24 ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
CNAS 3P/280 SHL W/YLW DCUL2547AWG24ROHS
1932615
CNAS 3P/280 SHL W/YLW DCUL2547AWG24ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
CNAS 4P/250 SIS W/DC+FERUL1007AWG24 ROHS
1932622
CNAS 4P/250 SIS W/DC+FERUL1007AWG24 ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30039738 CNAS 2P/850 SHL W/BL+FER UL1533AWG24ROHS
1932814
30039738 CNAS 2P/850 SHL W/BL+FER UL1533AWG24ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
35015033 SCREW C ZN YSMB M3X12 (ST) ROH
2756026
35015033 SCREW C ZN YSMB M3X12 (ST) ROH Befestigungsteile
30039440 CNAS 1P/100 PDP DIS W/TER ROHS
2772757
30039440 CNAS 1P/100 PDP DIS W/TER ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
20174894 BUTTON FUNC.TFT XX10-11 (EKO.G
2798562
20174894 BUTTON FUNC.TFT XX10-11 (EKO.G Gehäuseteile,Knöpfe/ Knopf/ Taste
20038260 BUTTON ON/OFF 7212/(7412 WO/TS
2799612
20038260 BUTTON ON/OFF 7212/(7412 WO/TS Gehäuseteile,Knöpfe/ Knopf/ Taste
30002583 KISA DEVRE TELI 06MM
7650157
30002583 KISA DEVRE TELI 06MM Verbinder/ Kabel/ Stecker/ Adapter
30001895 JACK 4P DIN TYPE FORSVHS
7651687
30001895 JACK 4P DIN TYPE FORSVHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
20023829 BUTTON ON/OFF 7212 SILVER
7652210
20023829 BUTTON ON/OFF 7212 SILVER Gehäuseteile,Knöpfe/ Knopf/ Taste
30012894 CONN HEADER 10P 2.5MM TOP WHT
1061789
30012894 CONN HEADER 10P 2.5MM TOP WHT Verbinder/ Kabel/ Stecker/ Adapter,Stecker
35000180 SCREW C ZN YSMB M3*6 ROHS
1061868
35000180 SCREW C ZN YSMB M3*6 ROHS Befestigungsteile
35008081 SCHRAUBE FÜR STANDFUSS M3*9.5, ROHS
1061921
35008081 SCHRAUBE FÜR STANDFUSS M3*9.5, ROHS Befestigungsteile
35008088 SCREW P C ZN YSMB 4*16 ROHS
1061922
35008088 SCREW P C ZN YSMB 4*16 ROHS Befestigungsteile
35008875 SCREW P C ZN YFSB 4X16 R8,5
1061957
35008875 SCREW P C ZN YFSB 4X16 R8,5 Befestigungsteile
30002181 SCHALTER TAST(4)
1063088
30002181 SCHALTER TAST(4) Schalter / Taster
35008812 SCREW P C ZN RYSB 3X10 ROHS
1063098
35008812 SCREW P C ZN RYSB 3X10 ROHS Befestigungsteile
30029642 CNAS 8P/600 SHL W/DC UL2464 AWG26 ROHS
1932889
30029642 CNAS 8P/600 SHL W/DC UL2464 AWG26 ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30002376 PWR CORD SAFE EU 1.45M CLASS I-PKG ROHS
1932919
30002376 PWR CORD SAFE EU 1.45M CLASS I-PKG ROHS Verbinder/ Kabel/ Stecker/ Adapter,Spannungsversorgung Kabel,Netzkabel
30001734 BRÜCKE SMD
7650163
30001734 BRÜCKE SMD Verbinder/ Kabel/ Stecker/ Adapter
basierend auf 9332 zertifizierten Bewertungen von zufriedenen Kunden
Jörg Paetzel vor 3 Monaten
Jens Renkwitz
Jens Renkwitz vor 2 Monaten
Barbara Zägel vor 4 Monaten
