Ersatzteile für Electrolux 642297
Electrolux
Sonstige
30001837 CONN HEADER 3P 2.5MM TOP BLUE SD ROHS
1062697
30001837 CONN HEADER 3P 2.5MM TOP BLUE SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30001838 CONN HEADER 3P 2.5MM TOP YELLOW SD ROHS
1062698
30001838 CONN HEADER 3P 2.5MM TOP YELLOW SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031051 CONN HEADER 2P 2.5MM TOP WHT SD ROHS
1932187
30031051 CONN HEADER 2P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031054 CONN HEADER 2P 2.5MM TOP BLUE SD ROHS
1932188
30031054 CONN HEADER 2P 2.5MM TOP BLUE SD ROHS Verbinder/ Kabel/ Stecker/ Adapter
30032632 CONN HEADER 2P 2.5MM TOP RED SD ROHS
1932190
30032632 CONN HEADER 2P 2.5MM TOP RED SD ROHS Verbinder/ Kabel/ Stecker/ Adapter
30032635 CONN HEADER 6P 2.5MM TOP WHT SD ROHS
1932191
30032635 CONN HEADER 6P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30032885 CONN HEADER 10P 2.5MM TOP WHT SD ROHS
1932193
30032885 CONN HEADER 10P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30037559 CONN HEADER 7P 2.5MM TOP WHT ROHS
1932200
30037559 CONN HEADER 7P 2.5MM TOP WHT ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30012384 CONN HEADER 4P 2.5MM TOP YELLOW ROHS
1932285
30012384 CONN HEADER 4P 2.5MM TOP YELLOW ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30012385 CONN HEADER 4P 2.5MM TOP RED ROHS
1932286
30012385 CONN HEADER 4P 2.5MM TOP RED ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30029522 CONN HEADER 12P 2.5MM TOP BLK ROHS
1932316
30029522 CONN HEADER 12P 2.5MM TOP BLK ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031582 CONN HEADER 5P 2.5MM TOP WHT SD ROHS
1932319
30031582 CONN HEADER 5P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30032793 CONN HEADER 8P 2.5MM TOP WHT SD ROHS
1932321
30032793 CONN HEADER 8P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter
30037560 CONN HEADER 12P 2.5MM TOP WHT SD ROHS
1932326
30037560 CONN HEADER 12P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30014654 CNAS 2P/660 FLT W/C UL2468AWG24 ROHS
1932387
30014654 CNAS 2P/660 FLT W/C UL2468AWG24 ROHS Verbinder/ Kabel/ Stecker/ Adapter
30018843 CONN HEADER SAFE 2P 7.92MM WHITE ROHS
1932432
30018843 CONN HEADER SAFE 2P 7.92MM WHITE ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031329 CONN HEADER 2P 2.5MM TOP BLACK
2755982
30031329 CONN HEADER 2P 2.5MM TOP BLACK Verbinder/ Kabel/ Stecker/ Adapter
30031056 CONN HEADER 3P 2.5MM TOP BLACK
2756175
30031056 CONN HEADER 3P 2.5MM TOP BLACK Verbinder/ Kabel/ Stecker/ Adapter
30041714 CABL 1P/600 DIS UL1672AWG22 RO
2774819
30041714 CABL 1P/600 DIS UL1672AWG22 RO Verbinder/ Kabel/ Stecker/ Adapter
30032640 BUCHSE SVHS 5P SEITE ROHS
2781235
30032640 BUCHSE SVHS 5P SEITE ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30047045 CONN HEADER 2X3P 2MM SIDE ROHS
2798262
30047045 CONN HEADER 2X3P 2MM SIDE ROHS Verbinder/ Kabel/ Stecker/ Adapter
30048570 BUCHSE PASSEND FÜR RCA 3P ROT/GRÜN/BLAU VERSION
2798691
30048570 BUCHSE PASSEND FÜR RCA 3P ROT/GRÜN/BLAU VERSION Verbinder/ Kabel/ Stecker/ Adapter
30049289 CONN HEADER 20P 1.00MM WHITE T
2798974
30049289 CONN HEADER 20P 1.00MM WHITE T Verbinder/ Kabel/ Stecker/ Adapter
30031127 CONN HEADER 3P 2.5MM TOP WHT SD ROHS
1932189
30031127 CONN HEADER 3P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30033112 CONN HEADER 4P 2.5MM TOP WHT SD ROHS
1932195
30033112 CONN HEADER 4P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031046 CONN HEADER SAFE 2P(V0)7.5MM TOP WHTROHS
1932318
30031046 CONN HEADER SAFE 2P(V0)7.5MM TOP WHTROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30048878 CONN HEADER 13P 2.54MM TOP WHT ROHS
1932334
30048878 CONN HEADER 13P 2.54MM TOP WHT ROHS Verbinder/ Kabel/ Stecker/ Adapter
30046579 CONN FFC 24P SMD 1MM SIDE ZIF ROHS
1932606
30046579 CONN FFC 24P SMD 1MM SIDE ZIF ROHS Verbinder/ Kabel/ Stecker/ Adapter
30040239 CNAS 5P/550 FLT W/C UL2468AWG2
2798423
30040239 CNAS 5P/550 FLT W/C UL2468AWG2 Verbinder/ Kabel/ Stecker/ Adapter
35022809 SCHRAUBE F. FUSS YSB M4X12 ROHS
4811904
35022809 SCHRAUBE F. FUSS YSB M4X12 ROHS Befestigungsteile
30001734 BRÜCKE SMD
7650163
30001734 BRÜCKE SMD Verbinder/ Kabel/ Stecker/ Adapter
