Ersatzteile für Electrolux 601878
Electrolux
Sonstige
35000185 SCREW C ZN YSMB M4*8 ROHS
1061883
35000185 SCREW C ZN YSMB M4*8 ROHS Befestigungsteile
35008181 SCREW P C ZN YSMB 3*16 ROHS
1061927
35008181 SCREW P C ZN YSMB 3*16 ROHS Befestigungsteile
35000194 SCREW S C ZN YSMB 2.9*9.5
1063067
35000194 SCREW S C ZN YSMB 2.9*9.5 Befestigungsteile
35000217 SCREW S C SYF YFMB 3.5*9.5
1063068
35000217 SCREW S C SYF YFMB 3.5*9.5 Befestigungsteile
30031051 CONN HEADER 2P 2.5MM TOP WHT SD ROHS
1932187
30031051 CONN HEADER 2P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031054 CONN HEADER 2P 2.5MM TOP BLUE SD ROHS
1932188
30031054 CONN HEADER 2P 2.5MM TOP BLUE SD ROHS Verbinder/ Kabel/ Stecker/ Adapter
30032885 CONN HEADER 10P 2.5MM TOP WHT SD ROHS
1932193
30032885 CONN HEADER 10P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30037559 CONN HEADER 7P 2.5MM TOP WHT ROHS
1932200
30037559 CONN HEADER 7P 2.5MM TOP WHT ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30037619 CONN HEADER 10P 2.5MM TOP YLW SD ROHS
1932201
30037619 CONN HEADER 10P 2.5MM TOP YLW SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
35005418 SCREWPCZNYSB3.5X10(KN1031T35X10)ROHS
1932230
35005418 SCREWPCZNYSB3.5X10(KN1031T35X10)ROHS Befestigungsteile
35014307 SCREW C ZN YFMB M4*8 (SILVER)
1932241
35014307 SCREW C ZN YFMB M4*8 (SILVER) Befestigungsteile
30012385 CONN HEADER 4P 2.5MM TOP RED ROHS
1932286
30012385 CONN HEADER 4P 2.5MM TOP RED ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30029522 CONN HEADER 12P 2.5MM TOP BLK ROHS
1932316
30029522 CONN HEADER 12P 2.5MM TOP BLK ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30031582 CONN HEADER 5P 2.5MM TOP WHT SD ROHS
1932319
30031582 CONN HEADER 5P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30032793 CONN HEADER 8P 2.5MM TOP WHT SD ROHS
1932321
30032793 CONN HEADER 8P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter
30037560 CONN HEADER 12P 2.5MM TOP WHT SD ROHS
1932326
30037560 CONN HEADER 12P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30014654 CNAS 2P/660 FLT W/C UL2468AWG24 ROHS
1932387
30014654 CNAS 2P/660 FLT W/C UL2468AWG24 ROHS Verbinder/ Kabel/ Stecker/ Adapter
30018843 CONN HEADER SAFE 2P 7.92MM WHITE ROHS
1932432
30018843 CONN HEADER SAFE 2P 7.92MM WHITE ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
CNAS 4P/250 SIS W/DC+FERUL1007AWG24 ROHS
1932622
CNAS 4P/250 SIS W/DC+FERUL1007AWG24 ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
40000109 ABSTANDSHALTER DCBS-10 ROHS
2756544
40000109 ABSTANDSHALTER DCBS-10 ROHS Befestigungsteile,Halterungen/ Halter
CABLE 1P/160 RED UL1061AWG28 R
2756749
CABLE 1P/160 RED UL1061AWG28 R Verbinder/ Kabel/ Stecker/ Adapter
35009300 SCREW P C ZN FYSB 4X16 (D:11)
2756750
35009300 SCREW P C ZN FYSB 4X16 (D:11) Befestigungsteile
30039440 CNAS 1P/100 PDP DIS W/TER ROHS
2772757
30039440 CNAS 1P/100 PDP DIS W/TER ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30041714 CABL 1P/600 DIS UL1672AWG22 RO
2774819
30041714 CABL 1P/600 DIS UL1672AWG22 RO Verbinder/ Kabel/ Stecker/ Adapter
30032640 BUCHSE SVHS 5P SEITE ROHS
2781235
30032640 BUCHSE SVHS 5P SEITE ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30033946 TRF SMPS SAFE 17WR02 (170-270)
2798801
30033946 TRF SMPS SAFE 17WR02 (170-270) Schalter / Taster
BRACKET SOCKET COVER MB15 H:54
2798867
BRACKET SOCKET COVER MB15 H:54 Befestigungsteile,Halterungen/ Halter
30042711 CNAS SAFE5-2P/400 DISW/DC FER1
2798908
30042711 CNAS SAFE5-2P/400 DISW/DC FER1 Verbinder/ Kabel/ Stecker/ Adapter
CNAS 8P/400 SHL W/DC UL2464AWG
2799022
CNAS 8P/400 SHL W/DC UL2464AWG Verbinder/ Kabel/ Stecker/ Adapter
20038260 BUTTON ON/OFF 7212/(7412 WO/TS
2799612
20038260 BUTTON ON/OFF 7212/(7412 WO/TS Gehäuseteile,Knöpfe/ Knopf/ Taste
CNAS 4P/450 SIS W/RED DCUL1007AWG24ROHS
4353497
CNAS 4P/450 SIS W/RED DCUL1007AWG24ROHS Verbinder/ Kabel/ Stecker/ Adapter
35000136 FUSE HOLDER TXT9-A (GRAY)
7650087
35000136 FUSE HOLDER TXT9-A (GRAY) Befestigungsteile,Halterungen/ Halter
30002583 KISA DEVRE TELI 06MM
7650157
30002583 KISA DEVRE TELI 06MM Verbinder/ Kabel/ Stecker/ Adapter
20023829 BUTTON ON/OFF 7212 SILVER
7652210
20023829 BUTTON ON/OFF 7212 SILVER Gehäuseteile,Knöpfe/ Knopf/ Taste
35000180 SCREW C ZN YSMB M3*6 ROHS
1061868
35000180 SCREW C ZN YSMB M3*6 ROHS Befestigungsteile
35008081 SCHRAUBE FÜR STANDFUSS M3*9.5, ROHS
1061921
35008081 SCHRAUBE FÜR STANDFUSS M3*9.5, ROHS Befestigungsteile
35008088 SCREW P C ZN YSMB 4*16 ROHS
1061922
35008088 SCREW P C ZN YSMB 4*16 ROHS Befestigungsteile
35008875 SCREW P C ZN YFSB 4X16 R8,5
1061957
35008875 SCREW P C ZN YFSB 4X16 R8,5 Befestigungsteile
35008089 SCREW P C ZN YSMB 4*10 ROHS
1063145
35008089 SCREW P C ZN YSMB 4*10 ROHS Befestigungsteile
30032684 SCHALTER TAST(4) 1N ROHS
1932192
30032684 SCHALTER TAST(4) 1N ROHS Schalter / Taster
30033112 CONN HEADER 4P 2.5MM TOP WHT SD ROHS
1932195
30033112 CONN HEADER 4P 2.5MM TOP WHT SD ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
35012594 SCREW M 3*8 YFMB TAPTITE (ROHS)
1932238
35012594 SCREW M 3*8 YFMB TAPTITE (ROHS) Befestigungsteile
30031046 CONN HEADER SAFE 2P(V0)7.5MM TOP WHTROHS
1932318
30031046 CONN HEADER SAFE 2P(V0)7.5MM TOP WHTROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30039348 CONN HEADER 6P-2 2.54MM TOP BLK DR ROHS
1932470
30039348 CONN HEADER 6P-2 2.54MM TOP BLK DR ROHS Verbinder/ Kabel/ Stecker/ Adapter,Stecker
30040239 CNAS 5P/550 FLT W/C UL2468AWG2
2798423
30040239 CNAS 5P/550 FLT W/C UL2468AWG2 Verbinder/ Kabel/ Stecker/ Adapter
30042842 CNAS 7P/300 SHL W/DC UL2464 AW
2798917
30042842 CNAS 7P/300 SHL W/DC UL2464 AW Verbinder/ Kabel/ Stecker/ Adapter
35000181 VIDA C ZN YSMB M3*8
7650084
35000181 VIDA C ZN YSMB M3*8 Befestigungsteile
